  • 5 Replies
  • 1195 Views
Matt1919
Can one tell me can you put a skin on and use a power cable all the time?
Can you use a power cable and a screw mount?
ChinJing
Luminary
Luminary
5 REPLIES 5
ChinJing
Luminary
Luminary
Yes, to all!!!
Matt1919
Ok thanks any recommendations for any?
Especially the power cable
The Arlo 90 degree cable works well with a threaded mount for outdoors. It can be tricky getting it properly inserted but that would be the same with any brand.
Matt1919
Great thanks
Where would you buy that from?
Do you have a link ?
Look at the products from the link at the top of these pages and then the accessories. There's an outdoor power supply as well as a solar panel which come with the proper cable. Remember that the connections have to be weather-tight on both ends.
  • 5 Replies
  • 1196 Views
