hi just wondering how to stop my arlo 2 pro cameras going of in the middle part of the day when the sun is at its brightest, they go off at lest every 2 minutes. This is happening on two of my cameras pointing straight out from under my eave. The one pointing back towards the house that has more shades doesn’t go of unless the is something there. As it doesn’t happen when it’s over cast or morning/evening or at night Thanks Peter
Any idea what triggers this "going off"?
Have you tried playing with "Motion sensitivity"?
Just another user
I have moved the motion sensitivity back to 70
Of course moving shadows can trigger motion. But wind can as well, especially if it is a different temperature than the still air. Even when that's not the case, dust carried by the wind can/will trigger the sensor.
Activity zones can help reduce the notification and recording rate, but they won't help battery life.
