How far from the base will the cameras work? I have three around my house that work great but I want to put one at the gate which is 3/4 mile from the house.
The cams connect to the base via normal 2.4ghz wifi... how far is base on wht the signal has to go thru.
Pretty sure it won't make the 3/4 mile tho...max range is listed at 300ft, ( tho I have gone a bit more in open ).
Your option may be a GO camera which works on cell connection... or a mobile hotspot with an ethernet port for an additional base
