- 2
I purchased the 5 camera set from Costco for $850 and I thought I had researched enough since there are so many options in the camera area right now. The issue I am having is that the push to talk feature is not able to be utilized, it is slow, quiet and sometimes can not even connect. I have 3 phones. 2 are on Android , one is on IOS. The IOS is a work phone so I don't use it very much. My connection to my home is 1 gig down, 40 meg up, Comcast. My ping times are usually under 10ms. I also purchased the doorbell to go with the system. All in with Arlo. The android phones in the home are both Samsung S9+ running the new version of Android (pie or 9, whatever you want to call it). The IOS is the latest, I think 12.0.3. On IOS, push to talk works great on the cameras. I have not tried the doorbell yet.
Has anyone in the community been able to get the Push to talk function to work on the cameras? Are you on Pie? Just wondering if there is a setting that I am missing on my phone that will allow me to utilize this feature on the cameras and doorbell.
Finally!!! thank for letting me know. I guess my suspicions were correct in the original post... could you direct me to the original thread or case so that I may be able to watch it and/or add my own experience?
Appreciate everyones help on this. While not a solution, at least I know I was not losing my mind.
My PTT is not working at all currently, on all cameras at 2 completely different locations, from 2 different phones and a PC. I'm getting rather tired of my Arlo's turning into garbage. PTT is failing, notifications are still broken, and I don't even get the video storage advertised that I'm paying for.
continuing to get "connection Failed, tap this message to retry" on IOS and android. PTT seems to work on my laptop at this time. I am getting very frustrated by this also.
factory reset has been done once before. I have opened a case with Arlo support and they have the link to this thread.
No. A factory reset is 80% of the time an invalid answer. Also I do believe I said that I have multiple base stations in different locations and different ISPs having this same problem, along w/ others here having it as well. This is an Arlo problem.
this has been resolved by Arlo team. thanks!
- 2
