Arlo Pro 2 (outdoor) with 20ft cable indoor...question
How many of you have outdoor cameras that are running off of a/c power?
I'd like to have all of my cameras plugged in but I'm not sure how to set mine up. Did you run yours under the easement and through the edge of the window, did you drill a hole somewhere and run the wire through the house and if so, where?
Also what did you do with the hole you drilled; cover it with a plate? When i do this i want it to look clean and not trashy.
The 20ft extension is third party , not Netgear equipment. ( Netgear recall the outdoor ac cable and will till new one comes ) Be careful with third party equipment as if an issue, Netgear may not support your claim
As to how to mount, that all depends on you setup/house. Drilled holes are easily fixed with expanding foam or caulk.
Prob the best way would be an outlet near the camera placement.
I had the usb cord covered by a strip of molding so it was totally hidden and out of sight except the 8" pigtail I left out to hook into camera,
I’m aware Netgear doesn’t have a workable charging cable but any recommendations for 3rd party products.?
I purchased one from Wasserstein but that was a piece of **bleep**E. Waste of money, failed to charge battery.🙄
Can you take a screenshot of the charging cable plugged into your camera please?
I want my camera to be permanently plugged in.
I’ve followed various threads regarding this product and it’s Hit and Miss. Works for some but not others.
Hi
Old thread but just got my Arlo pro 2, and rather fit the cable in right away. I see it mentioned (condenasation) a few times in many threads, in the UK it more the case of full outright downpoor of rain, would these cables hold up to such weather including gale force winds?
Thanks, Dan
I was going to get a 3rd party usb power weather proof cord but that voids warrenty, and again I would not regard moisture the same level as a full down poor of rain. Me getting these cameras has push my savings very low, cant afford to get replacements.
Dan
