Arlo Pro 2 notification not working with iOS 12.0
  • 6 Replies
  • 3547 Views
Jittmoon
Arlo Pro 2 notifications not working after updating iPhone iOS 12.0.
6 REPLIES 6
ValT_22
Try turning your Iphone off and back on again.  That worked for me.
Jittmoon
Thank you, but turning iPhone off did not fix the problem.  I am still not receiving notifications.  Does anyone know when Netgear / Arlo will upgrade the app to fix the problem?
JessicaP
Hey @Jittmoon,
Have you tried uninstalling the app, restarting your phone, and then reinstall the app?
Jittmoon
Hi JessicaP,
Thank you, I tried your suggestion but still not receiving notifications. Do you know when Netgear/Arlo will be upgrading their app to fix this problem?
JessicaP
Make sure to check you have the notifications turned on your device as notifications should be working properly on iOS devices. See here to make sure all your notifications are enabled: How do I enable and disable Arlo push notifications on my iOS device?
Jittmoon
Thank you. Problem solved. My primary user had to delete and grant me access again. I deleted the app shutdown my iPhone and reinstalled the app and it works now.
  • 6 Replies
  • 3548 Views
