Arlo Pro 2 notifications not working after updating iPhone iOS 12.0.
Try turning your Iphone off and back on again. That worked for me.
Thank you, but turning iPhone off did not fix the problem. I am still not receiving notifications. Does anyone know when Netgear / Arlo will upgrade the app to fix the problem?
Hey @Jittmoon,
Have you tried uninstalling the app, restarting your phone, and then reinstall the app?
Hi JessicaP,
Thank you, I tried your suggestion but still not receiving notifications. Do you know when Netgear/Arlo will be upgrading their app to fix this problem?
Make sure to check you have the notifications turned on your device as notifications should be working properly on iOS devices. See here to make sure all your notifications are enabled: How do I enable and disable Arlo push notifications on my iOS device?
