Arlo Pro 2 - CVR & Zone Not Working
The CVR on our Arlo Pro 2 camera is not showing the 24/7 recording. It was working just two days ago and then sometime after 9 AM yesterday it stopped working. Although I keep receiving emails saying that motion has been detected but no recordings to show for it. When I click on "Live" it'll play the live stream but I can't go back on the timeline. I've tried everything from restarting, rebooting, hard resetting, etc. and it's still not working. Our camera is a couple feet away from the router and base, the firmware has been updated, we have excellent WiFi signal so that's not the issue.
Also when I set up the activity zone it never records when motion SHOULD be detected. And all the settings are correct. It's very inconvenient and I've paid a decent amount of money for this system to work. So frustrating. Any ideas or solutions would be very helpful.
mbeee36,
For the Arlo Pro 2 to utilize CVR/Zones it needs to be plugged in. Is your Pro 2 plugged in? Are you seeing any error messages?
-Melissa
By any chance is the camera looking through a window? That would explain the issue.
CVR should work fine when plugged in and looking through a window. However, motion detection won't work since it requires the use of the PIR sensor and glass blocks the needed IR to set of a recording. I've seen motion detection on a P2 work through glass before but that was during the beta and firmware has changed.
Pro2 mounted under eave looking down on my deck records 6-9 seconds repeatedly but there is nothing moving
My front door camera includes a view of my driveway. Some days it records as I leave for or come home from work. Other days it does not. Today a 3 foot tall styrofoam bush cover blew across my front yard about 15-20 feet from the camera and it did not recognize the motion.
Did you get your camera to sync with the cvr? Mine is doing the same thing. Recorded for an hour and then nothing for days. Connected to power, detects motion ok, records clips. Just wont record to by $10/month cvr account which is assigned to this camera. Thanks!
Your issue is similar to mine mbeee36. One day CVR just disappeared off my system to never show up again or be able to be reenabled. Dont worry, they dont forget to continue charging you for it though.
Ramulous,
What are the issues you are experiencing with your system?
Mine's been working fine. What device and OS? Have you tried both the app and a browser?
