Wired Arlo Pro 2?
I have read that it's not good to have an Arlo Pro 2 wired... I have 1 camera inside right next to an AC outlet... can I use any USB adapter and microUSB cable and have it wired?
Yes, with the original adapter you can leave the Pro2 plugged in all the time...it will not hurt the battery
A standard USB adapter may NOT supply enough power to run the unit and WILL NOT charge the battery as the Pro/Pro2 use a dual voltage ( quallcom ) usb adapter
