  • 7 Replies
  • 1567 Views
mhmh
Library not recording. I have tried rebooting and making sure the camera is armed. Thought that the seven day library cloud was forever
7 REPLIES 7
Are you able to make a manual recording?
mhmh
No there is no icon to manual record. Also if i go to mode, rules, if motion is detected then do, the record video is greyed out
Start by removing and resyncing the camera.
This is with a Pro 2?  Normally this would mean that the camera has no subscription.  But the Pro 2 should have the 7-day cloud recording w/o a subscription.
mhmh
Thanks Stephen, I will continue to troubleshoot
Crawley
Do you have only pro 2 cameras, or do you have another newer Arlo device?
I have 4 pro2s and a doorbell. When I removed the doorbell the cameras started recording to the library again.
As a test, if you have a newer Arlo device try removing it, reboot your base and test the pro2 cameras.
FWIW, my pro 2s are recording (with a doorbell in the same account).  But my pro 2s are covered by a subscription.
  • 7 Replies
  • 1568 Views
