Arlo Pro 2 multi camera power adapter
  • 7 Replies
  • 6915 Views
_mcb
I’d like to plug 2 (or more) Arlo Pro 2 cameras into a single power adapter that is capable of charging the batteries.  Can anyone recommend a compatable 3rd-party multi USB port power adapter?
7 REPLIES 7
It won't work the adapter that came with the camera will only support 1 camera.
Not to mention the adapter is a dual voltage USB like Qualcomm
Also a 3rd party supply if there is one would void your warranty if any issues
michaelkenward
Sensei Sensei
Sensei
Is this just for charging the batteries, or do you want to have the cameras on permanent mains power?
If the former, than any USB charger will work. Arlo comes with a dual-voltage adapter, but a simple 5 volt charger will work with Arlo Pro 2 cameras. (Pro 1 may be different) I use a multi-USB adapter all the time.
I have not tried running cameras with a third party adapter, so can't comment if that is your goal.
Just another user
_mcb
Thanks for your response.  To clarify, I want to have 2 Arlo Pro 2 cameras, with batteries, connected to main power using a single power adapter.  I want the power adapter to be capable of keeping the batteries charged in case of power failure.
michaelkenward
Sensei Sensei
Sensei
That is a third scenario.
Always connected to the mains, but not using the Arlo features that need "always on" power, like zones.
I can't see why that would't work, but it seems like an odd requirement, so I doubt if many people have tried it.
Just another user
I doubt that the typical charges can supply sufficient current to run 2 cameras. The cameras will run off the external power normally and will keep the battery charged but the specs on the charger very likely only support one device being connected. Even if it did work, you'd be running the charger at its peak, reducing reliability.
michaelkenward
Sensei Sensei
Sensei
Are we talking about running the cameras?
I got the impression that it was about keeping them charged.
5 volts can charge a Pro 2, but don't you need 9 volts to run?
Just another user
If you plug in a camera, the power comes from the supply, not the battery. It really doesn't matter if you're keeping the batteries topped off - the cameras are getting power from the wall supply.
  • 7 Replies
  • 6916 Views
