arlo pro 2 wi-fi base connection
How do I connect my Arlo Pro 2 base station to the internet using wi-fi (not an ethernet hard wire)?
As noted in the instructions, you must use an Ethernet cable to connect the base to your router. The closest you can come to making it wireless is to use a WiFi extender and plug the Ethernet cable into that.
Thank you for useful reply.
I have ordered a TP-Link - AC2600 Wi Fi Range Extended from Best Buy
https://www.bestbuy.com/site/tp-link-ac2600-wi-fi-range-extender-white/5844809.p?skuId=5844809
