Arlo Pro 2 motion stopped working
  • 1 Reply
  • 1018 Views
JDPowell2
Motion has stopped working on one of my cameras.
Dannybear
Power cycle base first, check
If not fixed pull the camera battery and insert again, check again.
If not fixed try removing camera from settings then re-add, check again.
Contact Arlo support for advice.
If any of the above fixes then report back, monitor for recurrence. If it recurs within 48hrs then you may need to power cycle the base daily.
  • 1 Reply
  • 1019 Views
