  • 6 Replies
  • 7730 Views
grahamam107
Can anyone tell me where I can buy a QC 2 or 3 charger and cable for a arlo pro 2 camera?  I have read all the posts on the community about chargers andhave bought several chargers claiming to be QC 3 but they will not charge my camera.  I can charge the camera with a cable and charger that came with another camera I purchased, but need another charger.
I am not after generic advice like go to Jaycar or read the arlo community articles.  I have already done that.  I need a specific brand and model of charger that is proven to work.
Thanking all in anticipation.
@jguerdat wrote:
Any phone charger that supports both 5V as well as 9V outputs should work. Basically any phone charger should work although I suppose some newer ones may have modes that aren't backwards compatible.
 @grahamam107:  Many newer chargers are standard USB-C chargers, and only use USB power delivery.  This is NOT the same as Quick Charge (even though USB power delivery can also negotiate 9 volts).  And of course Apple chargers don't support Quick Charge, since it is a proprietary QualComm protocol.
The way to tell if a charger supports Quick Charge is to look for a lightning bolt on the charging port.
Quick Charge 5 is backward compatible with all previous versions, so no need to look specifically for QC 2 or QC 3..
Another option is to purchase a standalone battery charger like the VMA44000C
There are much cheaper third-party ones out there if you look on Amazon.  Arlo doesn't recommend them, but it could be worth the gamble.  If you go with a third party one, make sure it says it is compatible with the Pro 2 - chargers designed for Pro 3/Pro 4/Pro 5/Ultra won't work.
6 REPLIES 6
grahamam107
The first QC3 charger I bought did not work.  I purchased a second one and it works.  Thanks for encouraging me to persist.
grahamam107
I don't believe this is good advice.  I have tried other non QC 5/9/12 volt chargers and they do not work.
As I said above, there are USB chargers that deliver 9 volts but which do not support QuickCharge.   So @jguerdat's reply above isn't correct.
If you are referring to my comment that QC 5 is backwards compatible: that information comes from Qualcomm.
Well, incomplete. I didn't realize there are non-QC chargers with >5v  outputs although that seems reasonable.
  • 6 Replies
  • 7731 Views
