Three camera were recording a library (history). I now only get a library from one camera only
Two of three cameras are not recoding a history library. They were all creating a history but not now. How do I fix it so the two record a library?
If all cameras are pro2 then they should record to the arlo 7days free cloud storage and display in your library page of the app.
To confirm, live stream the cameras and manually make a recording, they should all show the manual recordings in your library.
Note: you can only have a max of 5 unsubscribed cameras per account.
Check the operating mode camera rules are correct.
Check the cameras motion detector is working using the motion detection test utility in the camera settings.
To reset the cameras, pull battery for 10sec.
