I was led to belive that a Arlo Pro 2 camera that is plugged in along with a paid suscrption should record 24/7. My system is timing out at 30 minutes. What settings need to be changed? Or any solution would be great.
Not just a normal paid account level, but you must add in the separate CVR option.
then it will record 24/7. ( go to live view and click on clock icon ( in web ))
timing out at 30 mins is normal without cvr option
Thanks.... Problem solved! Now do you think you can get them to lower the price?
