Arlo Pro 2 broken cable replacement
Hi. The charging cable (that came with our Arlo Pro 2 cameras) recently broke on one end (the micro usb end broke while trying to pull it out of the camera after charging). Would any micro usb charging cable work as a replacement? Am here in Canada and cannot find any official Arlo charging cables for sale. Thanks.
If you purchase a single pro2 camera charger adapter it comes with a cable I recall but I cannot see it on the shopping site anymore.
Any microUSB cable will work IF the plastic surround allows it to be fully plugged in. There are various ones out there with larger surrounds which prevent the electrical connections from being made since it can't be fully inserted.
thankyou!
