  • 4 Replies
  • 2546 Views
pathfinder196
Ever since the new software update to Arlo Pro 2 on our laptop (Windows 8.1), we can no longer see activity on our security cameras in live view.  The program asks for a newer version of Adobe Flash Player. Flash player is integrated with IE in windows 8. I have the latest version of Flash player on our laptop. Don't know what to do next. Don't want to use Chrome.  Anyone have any ideas?  I read from some of the other posts that Netgear is working on the problem.
pathfinder196,
Take a look at the troubleshooting steps listed here: Steps to troubleshoot Flash Player on Windows 8
pathfinder196
Thanks for the message. When I go to the site you suggested, I get the message,"flash player is integrated with IE in Windows 8.  You do not need to install flash player." So, I believe the problem is with the new software version that Netgear loaded in my laptop (2.6.0.937_24489).  All works fine on my iPhone and our desktop computer.
pathfinder196
Called tech support almost a week ago. Was assigned a case number.  I could not convince the support person that the problem is with their new version of software. Said I would be contacted within 24 hours to help solve the issue.  No response yet.  Like I said earlier, the software works fine on my iphone and Windows 7. Does not go live view using Windows 8.
There haven't been many complaints about W8 but I suspect it may be the same issue as with W10 and IE/Edge - a recent MS update is causing problems. Use of Chrome or Firefox works fine.
  • 4 Replies
  • 2547 Views
