Not able to adjust brightness any more after new app update
I can’t adjust brightness , there is not even a option it disappeared no more tab and I only got record speaker and mute, and pic not tab for brightness, I go into settings and adjust there and when I exit It goes back to the same setting before I could do live apple I phone.
It's in the camera settings. In the app, use Settings, My Devices, your camera, Video Settings.
I have also been having trouble trying to adjust the brightness and also by going to the setting is not saving. I believe it is a bug that needs to be fixed ASAP. This is a major issue. Why have cameras when you can't even see whats going on.
What device and OS are you using to set the brightness?
