Having just purchased an Arlo Pro 2 I’ve already captured some valuable footage on video. Do the time stamps have the seconds anywhere? I have two videos at 4.52pm but if I could see the seconds it would be so valuable
Message 1 of 6
5,133
The filename has the time in epoch time (seconds since 1/1/1970). You can use an epoch converter to get the full time displayed or check the properties of the video after downloading.
5 REPLIES 5
Great info here - thanks! I’m going to check out the Epoch converter myself!
Message 3 of 6
5,123
Thanks for the info. I take it you can’t see the file name on the app....can you only see on the desktop version?
Message 4 of 6
5,117
It's there when yo download it. I do note that the Android app downloads it without epoch time in the name - it actually lists the real time down to the second.
Message 5 of 6
5,099
Thanks. This converter worked perfectly for what I needed
Message 6 of 6
5,057
