Arlo Pro 2 ifttt
  • 2 Replies
  • 1660 Views
Retired_Member
Not applicable
Just got this and playing with settings. I checked ifttt while looking thru settings since my motion detection is no more than 20-25ft. Is this normal? I can see video much farther, but camera doesn't pick up any motion till it is within that range. Wifi is good.
I realized after doing some research, no need to select the ifttt option. But, now I can't find where I selected it and want to de-select.
Thanks for helping a new guy----
Can't help you with IFTTT issues but the 25 foot motion detection range is normal for PIR detector devices such as cameras and motion activated lights. It's the nature of PIR sensor devices.
Retired_Member
Not applicable
Thanks Guru
Was reading box and that is how it sounded. That said, things seem to working fine. The ifttt setting I checked doesn’t seem to be affecting anything.
  • 2 Replies
  • 1661 Views
