  • 5 Replies
  • 5133 Views
  • 2 Likes
Impress
Having just purchased an Arlo Pro 2 I’ve already captured some valuable footage on video. Do the time stamps have the seconds anywhere? I have two videos at 4.52pm but if I could see the seconds it would be so valuable
The filename has the time in epoch time (seconds since 1/1/1970). You can use an epoch converter to get the full time displayed or check the properties of the video after downloading.
5 REPLIES 5
Mjbeuke
Great info here - thanks! I’m going to check out the Epoch converter myself!
Impress
Thanks for the info. I take it you can’t see the file name on the app....can you only see on the desktop version?
It's there when yo download it. I do note that the Android app downloads it without epoch time in the name - it actually lists the real time down to the second.
Impress
Thanks. This converter worked perfectly for what I needed
  • 5 Replies
  • 5133 Views
  • 2 Likes
