  • 5 Replies
  • 3898 Views
robleves0143
Camera was working one day stopped. It will not  sink or operate eigther plugged in or one battery.
@robleves0143 wrote:
When I changed battery the blue and amber light alternate flashing?
Read the FAQ here on what the different LED patterns mean. Blue and amber alternating is during a firmwar update. Plugging power in, whether by battery or AC, results in a brief blue flash to indicate that power was detected. It's possible that you disconnected power during the update which left the camera in an indeterminate state. In that case, open a case with support here.
5 REPLIES 5
Pull battery and plug in the original adapter... does the led in front flash blue for a sec?
if not, contact Arlo support
robleves0143
robleves0143
I did as you said and the blue light was on for a couple of seconds and went out.
robleves0143
  • 5 Replies
  • 3898 Views
