Upgaraded from the standard pro ( no issues ) cameras to the pro2 and Every time I view any of the cameras in live there is a 30 second lag, and two way talk has a bigger lag. All have good wifi signal and record well.
Looking for a fix to be able to view with the usual delay of 3-4 sec not 30+
Is the firmware up to date? Even if so, try removing the cameras from Settings, My Devices and resync. Also, power cycle the base.
The Pro 2 cameras have recently had a firmware upgrade to increase their video bitrate and thus video quality. With the increase in bitrate comes a much higher data rate. If your internet speeds aren't super fast, the data is going to take a lot longer to upload to the Arlo servers and then a lot longer to download again to your app. What are you upload, download and ping numbers from www.speedtest.net ?
I have the same problem. Just unboxed and updated firmware. 78 ms ping, 80 Mbps down, 4.5 Mbps up. Should not be a problem. I may just return the laggy cameras.
XViper,
Are you using the mobile app or the web client? Do you experience the same behavior on both?
Just bought an Arlo pro 2 and see about a 5-second lag when I'm connected to wifi at home, but when I use the web app from work, it's about a 30-second lag.
The firmware updated during setup so that shouldn't be the issue. my internet is 12mbs download and 0.5 uploads.
Whats the recommended bandwidth for minimal lag?
Upload speed is 1Mbps minimum depending on how many cameras are streaming at once. Faster is better.
Thanks for the info! I'm updating my internet tomorrow with 200 Mbps download with 20 Mbps uploads. hopefully, that solves the problem.
Ping speed is also important. No use having a high transfer speed if your ping speed is stupidly high
Excited to use it, set it up in my kids bedroom. Kid went in and out the bathroom already but still lying on bed in my viewer. Crazy. Hope netgear release a patch soon. Thinking of selling it already while its less than 24hrs. No choice but to sell it lower price but its ok than feeling disappointed everyday.
Note. Syncing took me an hour. It was resolved only when insaw some post here that i need to power cyxle my router. Another crazy solution
That indicates a signal strength or quality issue. I would test the cameras at different locations/distances to see where things go downhill. What kind of distances are you trying to use? What is between the base and camera in a straight line (walls, ductwork, mirrors, metallic objects, house construction, etc.)? What other 2.4GHz wireless devices might be interfering with the base-camera signal?
