Retired_Member
Not applicable
2021-06-02
09:26 PM
I am trying to connect my Arlo Pro 2 base station VMB4000r3 with firmware 1.16.5.7_3823_a530306 to Apple Homekit. I have restarted the base station numerous times, and after hitting the Set up button, it is just stuck on "Discovering your device. please wait. Please help!
Message 1 of 6
4,373
HI @Retired_Member
I have reset your base station's HomeKit token. Please reboot your base station and try again.
Thank you
Message 2 of 6
4,335
5 REPLIES 5
HI @Retired_Member
Thank you
Message 2 of 6
4,336
Retired_Member
Not applicable
2021-06-07
03:03 PM
Thanks that worked
Message 3 of 6
4,332
Hi Shayne
Can you reset my base station's token as well please.
Thanks,
Adi
Message 4 of 6
4,242
Hi,
I need a reset on my base station's HomeKit token also. Thanks in advance!
Message 5 of 6
4,209
Thank you
