HW version H3, serial number 52M1837UA8910, firmware 1.125.11.3_26229.
I have found that if the camera is connected to main power and the battery is charging, everything is fine. When the battery is fully charged and the cable still is connected to main power, after a while the picture starts to flickering. If I unplugg the main power and operate the camery only on battery the image return to normal after some minutes. Why is this? Is the battery over charged?
Henko,
Can you try to use another battery in the camera that you are experiencing this issue with and test again? You can also try and put that battery in another camera and see if the same issue occurs. this will help isolate the issue.
