Arlo Pro 2 CVR
2 part question regarding CVR
1 - If I signup and cancel after couple weeks cause I am not satisifed, do I get pro-rated credit for unused portion of time?
2 - If I have CVR and a USB stick on the base, does it record anything or everything to the USB ?
Thanks all for your help!
1) I believe so, but not 100% sure... good question. Other plans have a montly option not sure if CVR does too
tho it does show montly fee here
2) Only TRIGGERED event go to the USB , the CVR does not... CVR is cloud based only
