Base unit to Modem to HD huckup
  • 1 Reply
  • 1290 Views
RVP
My Cable modem has an USB port to connect an external HD.  I was wondering since Arlo pro 2 base provided with USB ports to attach external HD for recording, what if you connect both modem and the base unit with an USB 3.0 dual power cable?  That way (I hope) you don’t have to remove the HD from the base to watch the recorded clips since modem has the access to the HD. Any one tried this or any thoughts?
USB DualUSB Dual
not going to work..... the USB on the base is to a dedicated drive or speed stick
but hey, be the one that takes the chance ( on your own ) and let us know how it works
  • 1 Reply
  • 1291 Views
