Hi - Appreciate your advice as a new user. I noted when using the Arlo Pro 2 camera indoors, with a floor lamp lit at one corner of the room, the recording is generally in night vision but to my surprise one of the recording is in color, just taken a few seconds later with no change in the lighting. Is there something wrong in that most are in night vision while the other is in color & all these recording are almost at the same time & under the same lighting condition.
Thanks.
There's obviously athreshold that causes the switch between lighting modes. It would seem that you're on the edge - adding or subtracting a bit of external lighting should help force the mode to be stable.
When I forst got my arlo Pro 2 last week I done some basic test in doors. I found that both cameras where slightly different in many ways. 1: the colour was mor vivid in one than the other, 2: the sound recording was better in one than the other some by quite some measure 3: one camera would change to night vision before the other.
It may be that Im unlucky but it seems each camera is not set up 100% the same as the other.
Dan
Thanks for your advice & comments. Much appreciated.
