I am so done with Arlo products soon... Expensive and buggy.. Now, after updating the iOS app everything is in German and I cannot find a way to change it back to English.. any ideas?
The suggestion about changing the language in the IOS settings doesn't work on e.g. IOS version 12.4 - since this version doesn't offer the opportunity to change language at all for the Arlo SW !
(yes, believe it or not, still have Iphone 6, and this is the latest available IOS version for this phone)
How to fix?
Arlo is on english in settings on my phone
Arlo must come up with a bugfix to this issue ASAP.
Change language back from German(suddenly occured last week) to english AS default. Work ok on my IPhone , but impossible to change on my IPad. What do I have to do. I live in Norway.
I have Norwegian as number one and English as number two.
I have set the app main language to English. But yet it sends notifications in german.
Du må sette språket på tlf til engelsk. Så gå inn på arlo via innstillinger og velge engelsk. så endre språket på tlf tilbake på norsk. da når du går tilbake på arlo via innstillinger ligger språk alternativet der. da velger du engelsk.
This issue should now be fixed on the the latest version of the Arlo iOS app, which is 2.19.1. Make sure to update to the latest version if you haven't done so already. You can read more about the newest version here: Arlo iOS App - 2.19.1 - 25th August 2020
If you're still experiencing this issue, please let us know.
highly appreciated the quick response to make a new version of the app !
Appears to be fixed now (v2.19.1). Thanks for the quick response to the problem!
