I have removed the device and reinstalled it more than 2 times in order to get it back to normal. It works but I cannot keep doing this!
8 REPLIES 8
I am experiencing the same issue.
HI @Zapunzel
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Hello, I experience the same problem with the Pro 2. No problems with the Pro.
Thanks in advance for any solution you may find.
How do you zoom with the pro 2? I’ve been trying to figure that out for months!!
You just use your both of fingers and pull outwards to zoom out and and push inward to zoom in. You do this under the video settings portion.
Hi, thanks for the reply. I removed and re-added it and it did the trick. Thanks for your help.
