  • 8 Replies
  • 3513 Views
  • 5 In Conversation
Cartagena
I have removed the device and reinstalled it more than 2 times in order to get it back to normal. It works but I cannot keep doing this!
ShayneS
Hi @Pppp2211
Have you tried to remove the ca era from Settings > My Devices & re-add it?
8 REPLIES 8
ShayneS
Hi @Cartagena
When you mention removing the device, did you remove from Settings > My Devices?
Zapunzel
I am experiencing the same issue.
ShayneS
HI @Zapunzel
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Pppp2211
Hello, I experience the same problem with the Pro 2. No problems with the Pro.
Thanks in advance for any solution you may find.
ShayneS
Hi @Pppp2211
t_welcome
How do you zoom with the pro 2? I’ve been trying to figure that out for months!!
Zapunzel
You just use your both of fingers and pull outwards to zoom out and and push inward to zoom in. You do this under the video settings portion.
Pppp2211
Hi, thanks for the reply. I removed and re-added it and it did the trick. Thanks for your help.
  • 8 Replies
  • 3514 Views
  • 5 In Conversation
