I am so done with Arlo products soon... Expensive and buggy.. Now, after updating the iOS app everything is in German and I cannot find a way to change it back to English.. any ideas?
My problem is with the Arlo App.
I have the Arlo App installed on my IPad Pro, and recently came back from my holiday in Southern part of Norway. When opning the Arlo App at home(southwest Norway) i was, for sone reason, logget out of the app (it stated that my geolocation was different from last time i was logged in).
When logging back in the language was not Norwegian.
My Ipad`s language is set to Norwegian, it`s location is in Norway both physically and in system.
I have logged out of the app, deleted it and reinstalled it, but still the App language is not in Norwegian. I think it is German, Swiss or Austrian.
Any suggestion?
Regards.
How can i changed to english ?
First go to settings on your iPhone and Select General/ Language and region . If Norwegian is your preferred language then add English as second language.
When this is done you go back to Settings and choose the Arlo app. Now you will have the option to choose language. Choose English and problem solved.
Case ID: 41876370
After update of app on Tuesday 18 Aug 20 to Version 2.19.0_5 the language was change from English to German. Make the Arlo tool/camera quite difficult to operate. I deleted the app and re-installed it and ended up With the same result. I don`t have a clue how I can change the settings for language. Arlo support made the problem and has to solve it ASAP. By the way - I think Your digital supprt service are to complicated and in the end not good for your buisness.
Quick support is mandatory
This is a fix for the language in the app, but notifications on iPhone and iWatch is still in german... Frome previous threads on this forum, it looks like this is an old problem, that came allive again...should be possible with a quick fix??
You are right. The development team is aware of the problem and hopefully they will solve it fast.
Perfect. That worked for me as well 🙂
Hi,
This is strange. I have no language setting withing the Arlo setting in settings. BUT when I go into settings - general - languages & region and change from Norwegian to English it works and changes to English. When I then try to change back to Norwegian it changes back to German. Cmon! Fix!
Then you can select English as language in the Arlo app.
Let us hope they fix the bug
Hi,
I found the solution that fixed it on iOS - iPhone:
As I was not able to choose language under Settings - Arlo (no choice came up) I did as follow:
Setting - General - Language and Region: Add english in addition to you own language
Then go back into Settings - Arlo and change to english.
This fixed it.
When I added english as language in Setting - Country & Regional - I was able to choose language to English under Settings - Arlo. I did not have a choice before. When I the chose English app was again back to english.
This worked for me. When changing to English on your phone, the language option on app settings appear and you can choose english. The switch the maine language back to norwegian.
Delete app, reinstalled , set English as language in settings... the result is english in app, but still notifications are presented in german language.
In addition also now experiencing instability with the connection to cameras/base station’s (have 2 separate systems) requiring me to log off and on to access cameras again.
(Seems like Arlo released this latest upgrade while test personnel was still on summer vacation..... )
Strange choice by Arlo...
