  • 1242 Views
HNDK
Hi,
I have just bought a Chime together with a Arlo Pro 2 set and an Arlo doorbell.
I'm trying to use the Chime together with the siren on the base unit in a mode where I wan't both the Chime to siren and the base station to sound the siren.
The siren sound from the Chime is the problem. There are a lot of crackling sounds together with the siren sound - and it doesnt sound very loud.
The chime functions as expected when used together with Arlo doorbell. Melodies and simulated "somebody home" sounds work as I expect. It is only the siren which is causing problems.
I have tried to moved the chime around the house in different sockets and ones very near to the base unit - no luck unfortunately. I've tried to reset the base station - no luck unfortunately.
Does anybody have suggestions for this issue?
Br. Karsten
It may just be a faulty chime. Swap at the store.
Jim_Cronin
Was the chime siren defective? Did swapping it out fix the problem? I'm having the same issue. Arlo tech support hasn't responded to my inquiry on this. Thanks.
@HNDK wrote:
Hi,
Br. Karsten
HNDK
Hi,
I returned it to the shop and received another one - unfortunately the new one had exactly the same problems. I decided to keep it despite this problem. But I am not impressed with this product from Arlo at all - which is a pity, because other products from Arlo are pretty great. But the overall impression of the brand suffer from this product.
Br. Karsten
  • 1243 Views
