Need help signing I to my account. Arlo shows AUTH error. Same login as Heere, same login to access the app, works fine but absolutely will not allow me
To update payment. Y’all deleted my last post.
Got resubscribed. Login from phone still doesn’t work.
https://ocapi-apparlo.com/api/auth: 0 Unknown Error
Are you using an Android or iOS device?
@LousyHardware wrote:
Iphone, safari browser
What version of iOS are you running on the phone?
Do you mean you are using the safari browser on the iphone? (guessing not)
iOS 14.3 iPhone 11 pro
All these things worked before. And no I’m not updating my phone I like it the way that it is. If that’s your “super user guru” response, then thank you for contributing to planned obsolescence.
Why would any of that matter.
I did not suggest anything - other than you give more information that would help troubleshooting. Details on the device and exactly how you are accessing do matter.
Are you running Safari on the iPhone to log in? Or are you using the Arlo app?
HI,
Can you PM me with your Public IP address as well as a time of when the issue occurs on your device. The development team will investigate this further.
Thank you
Hi,
Did you happen to receive my PM?
