  • 4 Replies
  • 2824 Views
Sc2
Arlo pro 2 plugged in (power supply is on and working) suddenly ignores my activity zones and records and sends alerts for every car going down the road.
I've removed and re saved the zones
I've restarted the base
I've re synched to the base
The constant alerts are annoying and considering I purchased the camera so I could set the zones and ignore traffic I'm upset it has stopped working 8 days into installing.
Streak2
Master Master
Sc2
The regular one that came with the app/cameras.
Streak2
Master Master
Arlo do change things from time to time. Your new system may have come with a demo of Arlo Smart.
According to the document I mentioned above you need to subscribe as follows:-
Arlo Smart Add-on
Enable Arlo Smart for individual cameras
$2.99
per month per camera
  • Enhanced notifications that tell you what Arlo sees and hears, right from your smart phone lock screen
  • User-defined motion zones to reduce false notifications
  • Filter unwanted notifications with person detection
Sc2
I declined arlo smart and it never had person detection. The system says you can set motion zones on the pro 2 as long as its plugged in which it is.
The last 2 hours its hit or miss one car it picks up the next it doesn't. Very frustrating!
  • 4 Replies
  • 2825 Views
