Smart Hub wall mount
Is there a wall mount bracket available for the Arlo Smart Hub base station?
sort of annoying to have it standing on a table, desk, bookshelf or similar
IIRC, the original base (the VMB3010) had a wall mount but I'm not sure the current models really support that due to their shape. Certainly a small shelf could be attached to the wall to do the same thing.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
