- English
- Services
- Arlo Home Security System
- Re: Primary PIN Setup takes a long time and does n...
I just purchased the Arlo Home Security System and trying to finish my set-up. In the Dashboard within the browser (on my laptop), I created a Primary PIN and hit save. However, it has stayed on "Please wait..." for over an hour. Have you all encountered this? I did this a few times and nothing has saved.
Also, in the App, I keep getting a "Public key required" when trying to set-up the PIN. I contacted customer service and it wasn't helpful. I had to unplug, reset, delete, and reinstall Arlo app, and it didn't solve anything.
Appreciate anyone's help with this.
Primary PIN
Public Key Required
Setting-up
Thank you for bringing this to my attention. I have escalated this for you & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 43999311
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
