  • 12 Replies
  • 1744 Views
josephfonseca
I purchased the keypad 3 months ago.
How do I activate the Arm at Home and the Alarm Away? On the phone and keypad?
Thanks...
@josephfonseca wrote:
I cannot get to the download you recommended...
How?
It is a pdf file.  What happens you when you click on the link?
12 REPLIES 12
Do you mean Arm Away and Arm Home? Or something about the alarm? As many details about what you're trying to do would be useful.
josephfonseca
I mean Arm Away and Arm Home...
Nothing else to do with the Alarm
How do I activate on the phone and keypad?
Thanks...
On the keypad, the left button at the top (empty house) is for Arm Away while the middle one (house with person in it) is for Arm Home. Press those as appropriate. In the app, go to the Dashboard and select the needed mode there.
You might want to read the documentation:
https://downloads.arlo.com/support/arlo-home-security-system/201-50585-02_Arlo_Home_Security_System_...
josephfonseca
How?
How?
josephfonseca
It worked!
I am printing it out now...
  • Thanks.
josephfonseca
What do you recommend to the Arlo Secure system including setups, tips, troubleshooting and services?
josephfonseca
I cannot install the "Install Guide".
If I click on it nothing happens.
I am referring to SH1001...
Thanks.
Thanks.
You said  you were printing it in post 7 - so I am confused.
The guide is just a pdf file, there is nothing to install.
josephfonseca
Ok...
Your recommendation is spot on. And I was able to print out the document.
Sorry for the confusion.
I was referring to the "Install Guide" SH1001...
Thanks.
Which is what you printed.  Not named properly on the website, since the manual itself is titled "Quick Reference Guide".
josephfonseca
Ok, thanks for the clarification.
Have a good day!
