Help Installing Arlo Home Security System
Bought the Arlo Home Security System SS1201 (First Arlo product that i bought)
Using ios 16.5.1, downloaded Arlo Secure app version 4.6.1
but when i launch the app to setup the keyboard hub
- Launch the Arlo Secure App.
- Confirm the Location where you want your device to be installed.
- Tap Devices.
- Tap.
- Tap Security System. <——— is missing
Only choices are: Camera, Lights, Doorbells & Chimes and Base Station/Hub
Scanned the QR setup code at the back of the keyboard hub and it brings me to the setup of chimes 2.
How do i install this? Is this a app bug? If it is, any other way to setup? Thanks
EL015,
Where are you located? The Arlo Home Security system has not launched in all regions and will not be available to onboard in the Arlo Secure mobile app if you're in a region in which the system is not available.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
