Hello everyone,
I'm encountering an issue with integrating my Arlo smart home security "sensors" with Google Home, and I'm hoping someone here might be able to offer some guidance or troubleshooting tips.
I have a setup consisting of Arlo door/window sensors and motion sensors. While I've successfully configured the door/window sensors to work with Google Home and receive notifications for door open/close events, I'm facing difficulties with the motion sensors.
Despite setting up the motion sensors in the Arlo app and ensuring they're configured correctly, I'm unable to receive motion detection notifications through Google Home. It seems that Google Home is not recognizing the motion sensor triggers.
I've tried searching online for solutions, but most resources seem to focus on Arlo cameras rather than the sensors themselves.
As you can see from the picture, this device is set up as a motion sensor within the Arlo app. However, in Google Home, it's being recognized as a door sensor.
Has anyone else experienced a similar issue with Arlo sensors and Google Home integration? If so, I would greatly appreciate any advice or insights you could share on resolving this issue.
Thank you in advance for your help!
Regards OOFe
google
home
Keypad Sensor Hub
Sensor
Hi @OOFe
At this time the behavior you are exoeriencing is the expected behavior. I have notified the appropriate team for an enhancement to allow for this feature. I will update this thread with any new info if changes are made.
Thank you
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
