My Arlo keypad was working fine, until today. No matter what I do, it won't connect to my WiFi. WiFi is 2.4 GHz and using WPA2. I've tried everything. Factory reset and all. Everything else is still connected to my WiFi (Arlo Pro 4 cameras via Smart Hub). I can still watch live videos from all 3 cameras from the app. Just the Arlo keypad is useless now. Only 4 months old. Please help. I have followed what other user experienced on this forum (turning off the hub and then try to reconnect the keypad only). Nothing works.
hello, I managed to get it back online again after 4 hours of intense battle.
What I did was turning off the router for at least 30 seconds. Turn it back on and wait a few minutes until the connections stabilized. On my phone, set to forget both 2.4 GHz and 5 GHz WiFi connections. Reset to factory default the keypad. Then connect to 2.4 GHz WiFi on phone and set to auto-connect. Add the keypad on the app again and it should be okay from there.
yapchagi,
I've reviewed the account that you have associated with the email address you're using here on the community and it appears to be showing your keypad is online. Are you still experiencing an issue?
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
