V Sim not working for Arlo Go - solution
  • 0 Replies
  • 1822 Views
  • 1 In Conversation
Cashtin
With Vodafone removing the use if the V-sim from the Arlo Go, I t looked into what other options were available.
The easiest, and what we have done, is to purchase a data only SIM from Smarty (https://smarty.co.uk/). Based on other discussion advice, we got the 2gb for £5/month.
The SIM card took two days to come. All you do is download the Smarty app, set up an account and then activate your card when it arrives. We put the SIM straight in the Arlo go, battery in a turned it on and it connected in around 2 mins from our Arlo app. We didn’t have to change anything in the app or add device. Now working fine. Plus, you can see hawk much data you are using through the Smarty app. 😀
0 REPLIES 0
  • 0 Replies
  • 1823 Views
  • 1 In Conversation
