I have 9 Arlo go cameras in various parts of a field. Because the shed in whichever my sheep spend a lot of time is important to view I have 4 cameras in there. If I have them all on at the same time there is a time lapse between them of quite a lot can be about 10 to 15 seconds delay on the worst ones. Any suggestions please? Regards Ann
Delay may be related to your bandwidth, can you check your up/down speeds?
Hi Tom thanks for your reply. How would I check up and down speeds?
If your smartphone uses the same provider as the Go cameras, then you could turn off the phone wifi, and test the mobile data speed with the ookla speedtest app.
Hi Stephen, thanks for the reply. I'm afraid the cameras are with Vodafone and phone is EE.
Modes et règles
