Geofencing stopped working
  • 91 Replies
  • 15633 Views
  • 6 Likes
  • 14 In Conversation
er-minio
I'm not sure if this is really a camera problem or and app/system issue.
Goefencing for my Arlo Go camera stopped working recently.
I tried resetting the geofencing zone, changing sizes, to no avail.
The phone has location sharing, background refresh, etc. etc.
There is another user, same, all settings are good on the other phone.
Geofencing has been working for years at this location, no big changes done apart from switching the SIM in the Arlo Go Camera at the beginning of August (V-SIM shut down) and Geofencing worked ok after that.
I have to manually arm/disarm the camera and, a couple of days ago, even disarming the camera wouldn't do anything as I would get movement notification (and movie recordings) despite the camera being set as "disarmed".
Is there some software issue? Update needed?
91 REPLIES 91
BrookeN
I do apologize for the frustration regarding Geofencing. Our development team is currently still investigating this. As soon as there is an update I will reach out to the community.
BrookeN
Are you still seeing this same behavior?
er-minio
As of yesterday, yes.
I can check again later today.
PickMonsterX
Still doesnt work for me and I have 3 location, which I pay for all of them.  I need a solution as this is a pain the the butt.
er-minio
Tested. Still not working.
Please fix this, it's been forever.
BrookeN
@er-minio can you let me know what you are still seeing regarding Geofencing.
er-minio
Thanks.
I’m away at the moment, but still wasn’t working until end of April.
er-minio
Still not working as of today, thanks.
alex_loo
Virtuoso
Virtuoso
my geofencing has NEVER been working properly, since I owned these 3x ultra 2 cameras + VMB5000 hub.
And that was since May-2024.  Yes, it's been more than a year now.
And when I say not working properly, I refer to to the following config:
  • 2 devices: 1x android + 1x iPhone.  Both logged into same master account
  • FEED interface
  • sometimes the geofencing routines DO get triggered, but the trouble is --- trigger or not, it's quite random
And I have been reporting this for at least 9 months.  ARLO sometimes acknowledges it while ignore me most of the time.  Most importantly, ZERO fix has been done.
Alex
It's generally, but not always, working for me on Android - I'd say ~80% working.
alex_loo
Virtuoso
Virtuoso
forgot this but are you having at least 2 devices that may arrive/leave individually?
what's the pattern with those 20%?
Alex
Yes, 2 phones are used for GF. The ~20% of not working is due to one phone or the other not being detected as away. There's no way for us to tell this so that info has come from an L3 I've provided logs to.
alex_loo
Virtuoso
Virtuoso
I am suspecting my situation is similar, but worse.  End up I have less than 50% working.  Simply unreliable.
I have also sent logs (some 1-2 months ago), but then I hear nothing.
Again this is what I am suspecting --- leaving is exactly the scenario when mobile is losing connection from home wifi and trying to switch to mobile data.  If mobile data coverage is not satisfactory (my case), geofencing logic really depends on how good the app is handling temporary bad network connectivity, when it is trying to send the "leave" status to cloud.  Say if the sending fails temporarily, will it continue sending some time later?  If it doesn't, then the whole geofencing logic will fail.
What I can say is that for the same phones, Google Home Automation is doing geofencing nicely, without issue.  I have even been using GHA geofencing to trigger ARLO routines, rather than relying on ARLO geofencing to do so.
Therefore, I am sure it's the way ARLO is implementing its geofencing badly, making itself a rubbish.
Alex
It's still possible that the phones' location services are at fault to some degree. I certainly don't pretend to know what the interaction between that service and the app is but I do see issues on my Android phone that makes me think it's somehow related to the newer Android releases (15 and 16). I also have a Lux Geo Internet-enabled thermostat that most times when using the app tells me to enable GF even though I did years ago and it's still working. My August smart lock is a guessing game as to whether it will unlock for me when I return home.
I suspect there's enough blame to be spread around between companies...
FWIW, I agree with you.  Something in the app has to be broken.
Another factor:  it doesn't work properly in both Android or iOS.
alex_loo
Virtuoso
Virtuoso
I don't quite understand what you are trying say, behind this "factor".
But I see the app not working properly, both in Andriod and iOS --- to be an expected result, if they are following the same ARLO app design logic.  It's just such "ARLO design logic" not right in the first hand.
Alex
alex_loo
Virtuoso
Virtuoso
I would definitely disagree about this point.
Android 16 here and except for ARLO app, other geofencing apps like Google Home Automation, Life360 are all running perfectly, they are peace of mind I can rely on their geofencing features.
But the ARLO app on the same device?  no way.  So none of the phone hardware, OS and location service are to be blamed.  It can only be the ARLO app, designed and written so badly.
convince me if you see otherwise.
Alex
That also suggests to me that the problem is in the app+cloud design.  The converse isn't true (app bugs certainly do show up only in the iOS app or only in the Android app).  But I think something that fails in both is almost certainly on Arlo.
er-minio
still not working as of mid July 2025
other geolocation services on my phone work correctly
BrookeN
Can you provide more information pertaining to what is not working in regards to Geofencing?
er-minio
I think I explained clearly last year, when it stopped working. I am the user that started this post.
My geofencing stopped working without me changing any settings.
I still have the geofencing area set (I also re-set it multiple times) and Arlo doesn't recognise when I am in the geofencing area anymore.
The app has all the iOS permissions (location settings, etc.).
er-minio
Ok.
Reinstalled everything once again. It seems to be working now.
One thing that is confusing is that the notifications when you enter and leave the geofencing zone are not happening.
And, yes, I have notifications enabled.
But this is a (way) smaller issue now.
In all of this, I'm stuck on the old app. Is there a way to change to the new one?
BrookeN
You can onboard on Pro 5 within the app and it will start the update. However, the Arlo Go1 is not compatible with the new app. And I have no updates if it will be in the future.
@er-minio :  You can, but the Arlo Go (version 1) is not compatible.  So if you have the VML4030, then don't do this.
BaubR
When the user in a face took a big change, not last software update, but the one before, my Geofence stopped working.  I have tried every combination of settings in the new interface, but none of them get it to work.
I logged onto the chat, and when it couldn’t give me any fixes, I asked to speak to a representative. It told me I didn’t have the right to speak to a representative.
my suggestion, stop buying Arlo products
