Geofencing stopped working
  • 93 Replies
  • 16696 Views
  • 6 Likes
  • 14 In Conversation
er-minio
I'm not sure if this is really a camera problem or and app/system issue.
Goefencing for my Arlo Go camera stopped working recently.
I tried resetting the geofencing zone, changing sizes, to no avail.
The phone has location sharing, background refresh, etc. etc.
There is another user, same, all settings are good on the other phone.
Geofencing has been working for years at this location, no big changes done apart from switching the SIM in the Arlo Go Camera at the beginning of August (V-SIM shut down) and Geofencing worked ok after that.
I have to manually arm/disarm the camera and, a couple of days ago, even disarming the camera wouldn't do anything as I would get movement notification (and movie recordings) despite the camera being set as "disarmed".
Is there some software issue? Update needed?
93 REPLIES 93
@er-minio wrote:
I'm using the free tier as I don't need any recordings and/or face recognition or other features in the subscription.
This is with the Go?  Or do you have the Go 2?  The Go does have free 7-day cloud recording.
In any event, access to Arlo support requires a subscription.  So if you want to try them, you'll need to subscribe for a month.  I'm tagging the Arlo mods - @JamesC , @ShayneS , @BrookeN - in case they have some ideas.
er-minio
It's the original Go.
It will keep recording stored for a few days when triggered. It's more than enough.
I'm not subscribing to open a ticket on a basic functionality that suddenly stopped working for me and other users.
I assume it should be solved regardless. it's a bug report, I can wait while it gets sorted.
BrookeN
I have reached out to the development team regarding the behavior you are seeing with Geofencing. Once I receive an update, I will reach out to the community.
er-minio
Thank you!
PaulB12
I have the same issue with Geofencing stopped working, I have 2 homes and both of them stopped working. I  use IOS and must manually set armed/disarmed.  Have double checked all the settings on the phone and still does not work.  I think something happened to the app?
Skisnkeys2
Are you using the newest version of the app?  When I upgraded,  the new functionality was a lot different and a bit confusing.  I had to
work my way through some of the settings to see what was missing.  The previous settings I had did not migrate completely.  Totally Arlos problem not a user problem.
If you have the new app I can go into more detail.
BrookeN
Are you still seeing this same behavior?
Skisnkeys2
No.  It turns out that when Arlo went to a new app it appears as though my Geofencing settings were not properly migrated.  Some settings were incomplete.   Very poor form by the developers.  I completed the settings and everything works fine.
er-minio
Mine is still not working. What shall I do?
It's getting a fair bit annoying.
BrookeN
@er-minio can you please make sure all your software versions are up to date.
er-minio
I'm running app version 5.2.1 (8623) relased Nov 8th.
PickMonsterX
Same issue for me.  I have 3 locations, they all worked fine.  Then after the app upgrade, I have to manually set home/away.  It's a real pain in the butt.
PickMonsterX
If I go into Automations, then press then TEST AUTOMATION, it corrects it, but it is still manual oof.
er-minio
What Automations? I don't have that.
I suspect that most of this confusion is due to the Arlo app having two completely different variants.
My app looks like this:
PickMonsterX
Video.
You have the older "Library" interface.  I am running "Feed"
PickMonsterX
I have feed to.  I'm running the most recent iphone app.  Still the geofencing doesnt work.
er-minio
Any updates on this?
It's been a few months now.
BrookeN
The development team was able to reproduce the issue as described and is continuing to work toward a solution. As soon as we have more information available, we'll post an update.
er-minio
Thank you!
NigeM
I had the same issue but I think I just solved this. Edit the Geofencing preset and under enabled devices I had 2 other phones included one being my main phone which displays the location icon, I’ve unchecked the other phones, saved and right away it went into ‘home’ mode. It has been able to do this for at least the last 12 months or more and I had previously given up. Hopefully this resolves my issue but I’ll fully test it later today. So in conclusion just make sure you only have one device enabled, the one that is always with you for the home and away function to work. Hope this helps others.
Beckisback
Good morning,
This still not working for me. Has there been any update?
Running the latest iOS with the latest Arlo app version.
er-minio
Still not working for me too.
It's getting ridiculous to be honest.
Beckisback
And to think they've just put their prices up...
Not the first issue that's been around forever.
My cameras still detect the animals and other motion despite all being set up for people only.
I would expect more...
Neaves
I’ve been having the same issue since the new app update late last year. Absolute garbage form by the developers. Support has been the worst I’ve ever experienced, probably be better if there was no support tbh. Thinking of turning the system for a refund see g we’ve just bought 3 new cameras to add to the setup and it’s still in warranty. Near $1000 AUD on something that doesn’t work as advertised.
