  • 1 Reply
  • 2431 Views
ArloGoVML4030
One rain fall and I get faulty charger connect correct one with the solar panel.... I tried vaseline on the connectors to keep moisture out but didn't help. Anyone had any success to correct the problem?
-Arlo Go VML4030-100PES SN: 51D Location: Sweden FW: 1.096.3.1_1.8.63.0_0 .6.5.19.GC.002 -
Check the seal on the cable to make sure it's unbroken and properly installed.
  • 1 Reply
  • 2432 Views
