  • 5 Replies
  • 2012 Views
Marc45
I just upgraded the app software per Technical support and I can’t control the length of recordings and motion sensitivity.
5 REPLIES 5
We need all details as to what you've tried and what you see. What do you mean by you "upgraded the app software"? Did you just update to the latest app or did you migrate your account from the old user interface (UI) that uses Library to view recordings to the new UI that uses Feed? Have you rebooted the phone and reinstalled the app?
Marc45
Ok I have the older Arlo go with the older software,it was working perfectly but will not let me invite other people to watch my camera
I called tech support and the made my upgrade to the new version.Now I can’t change motion sensitivity nor I can adjust the length of clips
After reading I saw the my Arlo go is not compatible with the new software.
Tech support made me do it,now I can’t go back
@JamesC , @ShayneS , @BrookeN any way to help here?
Marc45
Thank you
I have 4 of this cameras and I use them to rescue Dogs,now I can go back to the old version of the app
ShayneS
@Marc45
I can see your still on the old UI with the library option at the bottom of your screen. Do all of your granted access account see the Library or feed option at the bottom of the Arlo app?
  • 5 Replies
  • 2013 Views
