  • 3130 Views
2019bullitt
I've got the dreaded "charging fault, unplug and reconnect" I did that and still get the fault. I tried a new battery, no better. I've read over 50 responses but none for the arlo go. I only have the single plug, no adaptors, direct charge from panel to camera. It worked well for a couple months.
There's no difference between the Go and the others in this regard. The same issue has the same resolution.
2019bullitt
Since I've done everything that was suggested for the pro and it still won't charge, I need to replace a 2month old charger. Does someone make a better charger. I can't afford $80 every 2 months.
Have you opened a case with support for a replacement under warranty?
  • 3131 Views
