I dont even have my audio alarm set. Yet every time audio is detected, the motion detection is triggered and the camera starts recording.
Once again, Arlo is using it's users as BETA testers.
My Arlo Go has been a really cool device. Im just so tired of basic functions not working. This is blatantly poor BETA quality control by Netgear / Arlo.
Jabroni,
Audio will only start a recording if your rules tell the camera to detect motion on audio. Check your rules for the active mode and be sure Audio is unchecked for motion detection.
Again, audio is "unchecked".
Yet it is audio that is triggering the motion detection.
Every time a car drives by the camera goes off.
I check the recording and there is no motion. Only the audio in the background.
If facing the road, is it possible that the motion simply isn't captured due to the startup lag of any of the wireless cameras? Post a screenshot of share a video so we see what you see.
Of course, others have also reported audio detection when disabled. Have you tried resetting and starting fresh? Be sure to check your firmware against what's posted in the Release Notes area here.
I'll check the firmware. Regardless, as I said in my initial post, this should not be a firmware issue. Netgear shouldn't be releasing products that have so many blatant flaws that never should've survived the beta phase.
Jabroni,
If you have email alerts enabled, it should indicate whether the trigger is an audio alert or a motion alert.
Which subject line shows for your alert emails?
Arlo has detected a sound. Here are the details:
or
Arlo has detected motion on one of your cameras. Here are the details:
This should help determine if it is audio or motion triggering the camera.
If i stand behind the camera and yell, motion detection is triggered. Despite the notice subject line saying it was motion.
I can recreate the issue with consistency.
Time to open a case with support using the Contact Support link at the bottom.
Jabroni,
This is not normal behavior. I agree with jguerdat above and recommend opening a support ticket to further investigate this issue. Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Ive tried opening a case.
As has been in the case in the past, if I click "Submit Your Email" in the "Drop Us a Line" feature of the support center, the website crashes and fails to send my issue to Netgear.
If one of you moderators could forward this thread to the appropriate parties, I would greatly appreciate it.
JamesC wrote:Jabroni,
I just tested this on my computer and had no problem submitting the form. Not sure why this would be a problem for you.
Jabroni,
I have logged and escalated a support case on this issue. An agent should reach out to you via email as soon as possible.
Thanks a ton JamesC
Modes et règles
